1 - 11 of 11 Posts
Just found a nasty bird poop mark on my Atlas White IONIQ 5. Tried regular carwash soaps, baking soda and WD40 so far and cannot remove it. Ordered some special sprays from Amazon and wait to see if that works.
Anyone has some suggestions on how to remove those?
Sky Water Hood Cloud Grille
Ioniq 5 72,6kWh RWD Lucid Blue
Depends on the type of birds, but usually a shotgun will do.
2022 I5 SEL Lucid Blue
You can try a polishing compound and a microfiber cloth. Sprays probably won't do much, assuming you already tried the normal soap and water routing. If polishing doesn't work, you will probably have to take it to someone if you don't know how to use rubbing/cutting compound and the routine that follows.
Try a clay bar potentially. If that doesn't work I'd find a local detailer and see what they can come up with.
I am covering my car for the first time ever... new SE, regular parking spot in front of the house is under power lines, usually with 5-10 bird crappers hanging out on the wire.
I had my car ceramic-coated for this same reason. While I love the car, I don't think the materials, including the paint, are as durable as I would prefer. For this reason, I just didn't want to risk it. Once you have this issue remedied, I strongly suggest it.
2022 Ioniq 5 Limited Lucid Blue/Gray
3D Bug Remover from Amazon. If it doesn't work, then Meguiar's Ultimate Compound which is a on the "easy" scale when compared to using rubber/polish compounds and clay bars.
1 - 11 of 11 Posts
