41 - 50 of 50 Posts
Still didnt hear from Jejusoul. He is the expert in hexadecimal programming. Attached are the PIDS derived so far from the Kia Soul sets. EGR pids and TPMS wont work yet.
cant upload zips neither csv files. What forum server is this?
Here is Jejusouls Github link:
https://github.com/JejuSoul
A new log file with little more detail.
A very short trip, less than 8km. Cold ICE with an S1 phase up to 39C water temperature. In this phase i've left my home car park and cover 385meters. The fuel used in this short time frame was up to 13cl on 79cl of the total amount used.
Just to share with you.
Start SOC % 48.50 Value of HV Battery at the beginning of the trip
End SOC % 52.00 Value of HV Battery at the end of the trip
SOC difference % 3.50 Difference between end and beginning
SOC % charged by ICE 24.50 HV Battery amount produced by engine
Average SOC % 54.21 Mean value during the trip
Difference from best % -5.79 60% is considered the best value
Standard Deviation 3.23 Deviation from 60%
Min SOC % 48.00 Minimum value of HV Battery in the whole trip
Max SOC % 61.50 Maximum value of HV Battery in the whole trip
ICE off % 50.87 Percentage of trip time where the engine was off
EV % 50.87 Percentage of trip time where the car was running in EV
EV Range 4.30 Total distance traveled in EV mode
Trip length 7.95 km
Ignitions 10.00 Times ICE was turned on
Inefficient Ignitions 3.00 Times ICE was turned on for less than 5 seconds
Excessive EV 6.00 Times EV was used too much
Battery Stress 238.20 Quadratic average of battery current flow
Max Current 251.70 Maximum output current from HV battery
Min Current 228.10 Maximum charge current to HV battery
ParaGlide % 0.00 Percentage of driving time where the car was moving gliding (approximate value)
Longest ParaGlide sequence 0.00 Longest paraglide, in seconds
Average Coolant Temperature 51.34 Engine coolant fluid
Max Coolant Temperature 71.00 Engine coolant fluid
Time to reach 40C 0:02:43
Time to reach 60C 0:05:57
Time to reach 65C 0:06:31
Time to reach 70C 0:07:29
Time to reach 90C 24:00:00
Start Altitude 353.40 Altitude at the beginning of the trip
End Altitude 223.14 Altitude at the end of the trip
Delta Altitude -130.26 Difference from start to end
Min Altitude 217.42 Lower place
Max Altitude 373.75 Higher place
Average Engine Load 43.24 Mean value considering only non-zero values
Min Engine Load 12.16 Excluding zero values
Max Engine Load 57.65 Maximum value
Average Speed 36.19 Km/h
Top Speed 89.00 Km/h
Average Absolute Speed Variation 3.02 Speed variations during the trip (only while moving): measure your driving style
Max RPM 2338.00 RPMs
Average RPM 1563.00 RPMs
Trip length 7.95 km
Fuel used 0.57 litres, as reported by Torque
Fuel economy 13.87 Km/L
Best fuel economy 16.29 Km/L
Fuel consumption 7.21 L/100Km
Average Accelerator % 19.66 Accelerator Pedal Usage
Standard Deviation 4.76
Average Absolute Accelerator Variation 3.61 Accelerator variations during the trip (only while moving): measure your driving style
Analysis for car type: HSD
Check Log sheet for additional info
R43
How can I get thoses dates in my ioniq hybrid? Thanks in advance
Hello.
I'm the developer of an Android App called the "PHEV Watchdog" (freely available on the playstore)
It's essentially a monitoring tool which retrieves through the communication OBD2 port the car's data and shows this on the App.
It will show the actual battery status (charge, health, voltage, temperature, etc...), cells, e-motors, and engine.
It will also keep track of the battery degradation and all your trips recorded with the App.
Beside that, the App syncs to a online server which consolidates all data between all users.
Look for phevwatchdog.net website and to see the live data, use user: showme password: showme)
I've developed this for the Mitsubishi Outlander PHEV, but lately I've been asked by other to support the KIA/Hyundai PHEV models.
In order to do this I'll need the help of KIA/Hyundai PHEV owner's has I do not have myself a KIA/Hyundai.
I've been doing some progress with the help of two owners for the OPTIMA PHEV and Niro HEV, but I'm missing the support for the Ioniq PHEV.
If someone with a Ioniq PHEV who has an OBD2 adapter (necessary, so the App can communicate with the car) is willing to provide me some help, please contact me.
I'm only interested on PHEV's now, as I believe there's not too much work to add support to other PHEV models, but afterwards the plan is to add support to the EVs models.
Thanks!
Thanks!
I've been hoping for an app like this, so have just ordered an OBDLink MX Bluetooth v3.0 and will contact you when I have it installed and set up. Thank you!
So to not hijack this post, I'll be continuing the Watchdog subject here:
Thanks
41 - 50 of 50 Posts
