41 - 50 of 50 Posts
I opened a ticket with customer relations at hyundai canada ([email protected]).
They referred the case to mapnsoft. William at MapnSoft replied with: "Thank you for your patience. To correct this issue you will need to reach out to Hyundai Customer Care, and then ask specifically for them to "set the flag to active on the server for the red light camera feature". After doing this, please perform a soft reset on the vehicle, by pressing in the small pinhole button near the display. This should resolve the issue. "
I sent this info back to hyundai canada ([email protected]) - who said everything looked okay on there end and referred me back to mapnsoft ! Frustrating
I then did another software update with the new Apr 29th software update package - version NEEV.CAN.S5W_M.V008.001.220504
The first Apr 29th update was Software Version NEEV.CAN.S5W_M.V008.001.220419
All his working correctly now.
It's easier to do the update than to phone and email Hyundai Canada.
It's good to know they released an update, even if they didn't advertise it. Since they fixed mine internally, I'm loathe to run the update in case it screws it up again 🤣
Discussion Starter · #47 ·
Speed cameras detection back to not working on my latest UI revision, email sent otherwise I give up.
Check if the warning is working tomorrow. Once they made a change and reactivated bluelink to my car, it worked the next day, not soon after the reactivation.
Check your current Software Version (SetUp -> General).
If it is the current software NEEV.CAN.S5W_M.V008.001.220504 then try resetting the head unit:
1. Go into your vehicle and turn on the engine.
2. Find a small hole under or around the volume or tuner button.
3. Insert a thin object such as; a toothpick, paperclip, pin, etc... into
the hole (in the event that you do not find a small hole, please press
and hold the MAP + SETUP buttons simultaneously). Hold for 5 seconds, and
then retract the object from the hole (or let go of MAP + SETUP).
4. Once released, please wait for 15-20 seconds so that the system resets properly.
5. Once the 15-20 seconds have passed, reinsert your object (OR press and
hold MAP + SETUP) once more for 5 seconds and then retract.
If your current Software Version is the previous one NEEV.CAN.S5W_M.V008.001.220419 then you'll need to use Navigation Updater.app to redownload the latest software. It still says Apr 29 but the software has been updated to the newer version.
The current Canadian Hyundai Software versions can be found at here.
2022 AWD Ultimate Johnny 5
Thanks for the reply but I am already on the latest UI software 220504 version and have tried the reset procedure you have described. Will just have to wait for Hyundai's reply I guess.
2 Final Ideas:
1) After I updated to NEEV.CAN.S5W_M.V008.001.220504 I received an email from [email protected] saying :
Congratulations on your new vehicle purchase!
You have already started your registration in your vehicle. To complete your Bluelink registration, please use the
following link: https://mybluelink.ca/login?token=tTk2Gibsqt
Alternatively, you may go to https://mybluelink.ca/login, log in using the email and password you set up, and
complete the registration using the following registration code: tTk3Gqtshr
If you have any questions, please contact Customer Care at 1-844-258-5656.
I did this before the Red Light Cameras reactivated.
2) Go to Setup -> Navigation Settings -> Alerts -> Camera Alert Distance and make sure one of the options is selected.
Good Luck
41 - 50 of 50 Posts
