HUUUUGEEE Update::: I sent an email to service at bluelink Canada this morning
Got a reply below about an hour later
Thank you for contacting Hyundai Canada Bluelink Support. We apologize for all inconveniences that you may be facing regarding your concern.
As a follow up to your request regarding the Bluelink Service and the speed camera warnings, we have created a ticket to the technology team for further analysis. Once they have reached a solution, we will be in contact with you by email with further instructions.
In the meantime, please perform a Head Unit Reset after the update.
Below are the steps to perform a Vehicle Head Unit Reset.
This will potentially reconnect your vehicle and allow Bluelink to properly communicate with your vehicle's Head Unit once more.
1. Go into your vehicle and turn on the engine.
2. Find a small hole under or around the volume or tuner button.
3. Insert a thin object such as; a toothpick, paperclip, pin, etc... into
the hole (in the event that you do not find a small hole, please press
and hold the MAP + SETUP buttons simultaneously). Hold for 5 seconds, and
then retract the object from the hole (or let go of MAP + SETUP).
4. Once released, please wait for 15-20 seconds so that the system resets
properly.
5. Once the 15-20 seconds have passed, reinsert your object (OR press and
hold MAP + SETUP) once more for 5 seconds and then retract.
Once all the above steps are completed, please reply to the email.
Thank you kindly for your time.
If you have any other questions, please visit the FAQ section on our website at
Connecting.... You may also contact us by email at
[email protected] or by phone at 1-844-258-5656.
Kind regards,
Angie
So I was out driving and no response to the speed camera in the area at all. No warning or nothing.
After about 45 min after I go the reply email above I was returning home and all of sudden the voice came on and told me about a speed camera. I was super happy
Looks like it is a backend issue from Hyundai Canada Bluelink.
I am very happy to have it back, Thank you all and Bluelink as well. Not sure what they did but it worked.
Now it works perfectly
NOTE: I did not do the reset like they said in the email I did nothing and it starting working on its own.
Hope this helps others
Chris in Edmonton
