1 - 10 of 10 Posts
· Registered
2019 Ioniq 28kWh
My 2019 got three tires warning within like 5min when it was -15celcius outside. I thought it was due to low pressure, but when it got warmer the pressure rose again, but the warning remained for like a week then it went away.
Numbers shown were all in the range where I would not expect a warning(2.2kg)
· Registered
Everything suggests the warning should clear within 10 miles (used to happen almost instantly on my Veloster) but this is the first time I have ever had the warning on the i5 and it refuses to go away. It is very cold in the UK right now, not sure if that could make a difference?
You need to inflate the tyres more to clear the fault. They should be at a min of 36psi when cold.
· Registered
2022, Ultimate (Tech)
I had exactly the same issue , but it cleared after a couple of days . The tyre pressures were showing 34 even after inflating to 36. Eventually a couple of days later it went up to 36 as I was driving to get it inflated again .. and the error cleared
1 - 10 of 10 Posts
