61 - 80 of 287 Posts
This isn't a complaint, but it is a head-scratcher.
In the back, just above the rear bumper, there are three - what look like - lights on each side. A white one, a yellow one, and a red one. The white one's easy, that's the backup light. However, I can find nothing that uses the other two. They don't go on with turn signals or tail lights. Don't know about brakes, but I doubt it.
Many other countries in the world require turn signals to be yellow, but the US doesn't (I actually prefer the turn signal to be yellow). As near as I can figure it from what I've been able to find, the yellow one is used as the turn signal in countries that require it and it's just an unused position on the US models. (It would be interesting to take it apart to see if there's actually a light assembly back there, but I'm not that motivated.)
If I'm right, this makes absolutely no sense. Why incur the cost of having different tail light/signal versions when one will work everywhere. Yellow turn signals may not be REQUIRED here, but lots of cars have them.
Your guess is as good (or probably better) than mine as to what the red one is for. Maybe it's just a reflector, but it doesn't look like one.
Do you mean this?
My guess would be these light are used when the hatch is open, such as when transporting larger loads?
Do you mean this?
Motor vehicle regulations in many jurisdictions require vehicles to have at least two red reflectors on the rear, either as part of the tail lamps or separately, to enhance visibility at night and ensure road safety.
Here's a more detailed explanation:
  • Purpose:
    Red reflectors are crucial for enhancing the visibility of vehicles, especially at night, making them easier for other drivers to see and avoid accidents.
  • Requirements:
    • Number: Most regulations require at least two red reflectors on the rear of a vehicle.
    • Location: These reflectors should be located on opposite sides of the vehicle, one on each side of the vertical centerline, and as far apart as practicable.
    • Visibility: The reflectors must be visible at night from a distance of 300 feet to 50 feet.
    • Integration: Red reflectors can be part of the tail lamps or mounted separately.
  • Specifics by State:
    • Ohio: Section 4513.06 of the Ohio Revised Code specifies that every new motor vehicle sold after a certain date must have two red reflectors at the rear.
    • California: California Vehicle Code § 24607 addresses red reflectors, stating that when more than one reflector is required, at least one shall be mounted at the left side and one at the right side, respectively, at the same level.
    • Texas: Texas Transportation Code § 547.325 states that a motor vehicle, trailer, semitrailer, or pole trailer shall be equipped with at least two red reflectors on the rear of the vehicle.
How lucky are you!!!
Mine does, too. Just not iPedal.
Mine is set to max regen on level 3, and I use the left paddle to slow and/or stop. It remembers this setting, which happens to be the most similar behavior to our '21 Bolt.
I don't use iPedal any more.
Edit to add: Based on your post #66...my 2024 Ioniq 5 RWD LR LTD does remember the Auto regen setting. It's at Level 3 Auto when I start it up. I don't need to change a thing.
It remembers Levels 0, 1, 2, and 3. It steadfastly refuses to remember Auto or iPedal and there's no reason for that. It's just a stupid annoyance.
This is exactly how it works on our 2023 Ioniq5. Interesting, it is supposed to work the same on our 2025 Ioniq6 though I’ve noticed even the other levels are intermittently non-sticky. I usually drive in AUTO, sticky on the 5. On the 6, it is sometimes sticky but occasionally reverts to 1, or 3. Very odd behavior…no one else driving, no other profiles set up yet.
It's more than just an annoyance. I've pretty well trained myself that I need to tap the left paddle every time I start up the car, but I sometimes forget that shifting to reverse exits iPedal and reverts to level 3. It's borderline dangerous if you expect that taking your foot off the accelerator will bring the car to a complete stop and it actually doesn't. I've had a few situations that required a more abrupt application of the brake when I suddenly realized the situation.
Strange. Our Bolt remembers One Pedal Driving (OPD) and it stays in OPD even in reverse. Lots of folks on the Bolt forum complain about that last feature. But I do like the consistency of the car behaving the same in both directions.
Ha!
1. I want to use Sport Mode every time I get in the car. I have no use for the other modes and don't want to default to Normal Mode.
2. The stock rear shocks are garbage. When I replace them, I'll probably replace all 4.
It sucks that I only have 3500 miles on the car, because I made it 60,000 miles on my previous car before I needed to replace/upgrade the struts and shocks.
3. I don't want to ever see the safe-driving popup warning ever again.
Please tell me how to disable this repetitive warning that serves no useful purpose!
4. I don't want i-pedal, but I'd like a "1.5" regenerative brake setting. More than setting "1", but without the triggering of the brake lights of setting "2".
4. Everybody needs to be reminded that it's not the 20" wheel diameter that hurts range, it's the 255mm wide tire mounted on it that causes the range loss (aerodynamics are more important for most drivers than weight for general efficiency. (I don't care much about range and bought 265 tires for summer use, and I'm mounting them on 20" aftermarket wheels that are each 15 lbs lighter than OEM!)
What are you replacing the Ioniq 5 rear shocks with? I hate the floaty feel when on curving freeway ramps. One time, it felt dangerous.
Supposedly, Kia's sister vehicle, the EV6 has stiffer rear shocks that are drop-in replacements for the Ioniq 5, and improve handling, but I can't get an answer out of anyone whose done it. The EV6 rear shocks are relatively inexpensive, at $250 for the pair, so I may take a chance...
Agree, consistency is better for safety.
Arob: I tested it with the hatch open. Still no lights (also, the regular lights are still visible with the hatch open).
Neil F: That might explain the red one, but on my car there's a white and a yellow, too. The white most likely the backup (can't test it by myself), and the yellow one still does nothing.
I have the rearview mirror camera (that I really like), and have zero need for a rear wiper.
I've already benefitted from the rear wiper multiple times driving in wet weather. Road spray quickly obscures the windshield if there's much of anything on the ground, so I appreciate being able to clear it.
Welcome. You think you have it bad? They fixed a ton of stuff in the 2025. But why they didn't fix the iPedal and Auto regen settings, I'll never understand. Plus not being able to change them unless the car is moving, foot is off the brake, and cruise control is not engaged? That's just stupid. Extra programming just to annoy the driver. Totally ridiculous.
Mine is an SEL because I don't want a glass roof cooking or freezing me. Or breaking. Or leaking. But I do want the 360Âş camera and the ventilated seats that my el cheapo Bolt EUV has. Sorry, you want 360 camera and ventilated seats? You gotta take the reduced range that comes with the big wheels and glass roof. In a couple years, I may upgrade and see if they will swap the wheels for sensible ones.
But like you said, in spite of the apparently deliberate annoyances, it's still a delight to drive.
It's possible that this was covered in a software update, but on my brand-new 2025 i5 Limited, I can adjust the regen setting to Level 3 as a profile option, so that even though I don't get the i-Pedal automatically, at least I still have the strongest regen that carries over between drives. That might not have been true in Feb when you wrote your post.
Also, I can adjust the regen settings at a full stop. It seems the only time I can't change them is if I'm slowing down with my foot on the brake pedal. Again, might have been changed in a more recent update.
Re range: So far, I haven't seen any evidence that the larger tires actually impact the car's range all that much. From what I've been seeing, the advertised drop has to do with EPA estimates that factor in the size of the tires, but as with all cars, EPA estimates are under "idealized" conditions and don't reflect real-world conditions. My car consistently thinks I've got over 300 miles of range at 100%, and that I could achieve even better than that with efficient driving. I haven't driven it enough on one charge yet to see if that would hold true, but I'm an efficient driver, so when I eventually do get to run down the battery a bit, I'll see if I do get a better range than advertised. It would be nice for the EPA estimate to be too low for once.
Reactions: thutchis978
My '24 does the same. I'm not sure if it's part of the profile or not since my profile just has my Bluelink login info. I think it just remembers any regen setting other than Auto or iPedal.
owns 2025 Hyundai Ioniq 5 Limited RWD
Definitely a personal preference kind of thing. I'm curious, do any manufacturers other than Hyundai/Kia have selective levels of regen?
Technically, the combination of settings on Tesla vehicles gives them similar levels of regen. You can select regen strength (high and low, basically) and stopping mode (roll, creep, and hold).
With low regen + rolling, the car basically does minimal regen.
With low regen + creep, this is essentially medium regen.
With high regen + either mode, I'd call it strong regen.
And with hold mode, it seemed to give me the strongest regen.
However, this is definitely more complicated (and has some redundancies) compared to the honestly simpler settings in the Ioniq.
Did Tesla bring back low regen setting? There was news articles a few years ago that they had removed that option by software update.
It was always available on my 2019. It's possible they had removed it in later models.
Reactions: ioniqfam
