Apparently I've been doing it all wrong? Usually I just turn on the heat button, crank the temperature dial to 25 degrees (example) and leave A/C button off in the winter to bring in hot air into the cabin.
Apparently someone told me that doing this is not efficient because it makes no use of the heat pump. This person said I should be doing the reverse to make use of the heat pump, so turn off heat button, turn on AC button, and crank temperature dial to 25 degrees (example). This person said I'd use less power to get heat.
Is this correct? I haven't tried it but I didn't think it worked this way...
Ideas?
Ideas?
