Dear All
I've been having problems with the 12v auxiliary battery in my 2019 Ioniq BEV. Shortly before Christmas I drove the car for around 30 minutes and then sat in it for 2 hours while connected to a level 2 charger (with ignition off); at times I switched on HVAC as the windows misted up. I then drove 20 miles home and the car behaved perfectly normally. Next day I tried to start it but there was zero response and ended up calling Hyundai/AA Rescue who diagnosed a flat 12v aux battery, jumpstarted it and recommended I leave the car switched on in P for a couple of hours to let it recharge fully from the high voltage battery. Since then I've been monitoring the 12v battery using a multi meter with the ignition switched off and it never achieves more than 12.3v and frequently drops to 12.1v which seems very low to me; with the ignition on it reads around 14.7v. It makes no difference how often the car is driven or how long it's left sitting on the drive switched on in P: it never gets higher than 12.3v. The aux battery saver function has been enabled since day 1 and although I'd noticed the blue dash light flashing at times in the weeks before the problems started, I've not seen it since and never seen any dash message to say it's been on. The car has been starting normally, but at no more than 12.3v, I'm not convinced that it would take much for the battery to fail again. Covid-19 permitting, the dealer is going to test it at end of this month, but in the meantime I wonder whether anyone has any thoughts or similar experiences. Thanks!
